Starbrite View Guard 650ml Clear Plastic Treatment
£20.29 (ex VAT)
£24.35 (inc VAT)
View Guard clear plastic treatment is an industry first: a wet weather visibility enhancer specifically formulated for use on clear plastic enclosures such as Strataglass, EZ2CY and Eisinglass. Specially designed surfactants safely remove dirt and grit while advanced polymers repel rain, spray and salt to provide maximum visibility, even in heavy weather conditions. View Guard also provides a barrier to damaging UV rays that can cause clear plastic to crack and turn yellow.
- Repels water to enhance wet weather visibility
- Specifically formulated for use on Strataglass, EZ2CY, Eisinglass & other clear plastic surfaces
- Repels water, spray, salt & dirt
- Gently cleans clear plastic surfaces
- Provides protection against damaging UV rays
- Cleans & provides UV protection for all clear plastic surfaces
- Dramatically improves wet weather visibility
- Repels spray & rain to enhance wet weather visibility of clear plastic enclosures
- Removes grime, salt, spray & dirt
Directions: Spray on surface to be treated and use clean, soft cloth to apply in a circular motion, working in areas approximately 18" by 18" in size. Turn cloth over and wipe completely dry. Do not let dry before wiping. Use as often as needed. For yellowed, hazed or lightly scratched clear plastic enclosures, use Starbrite Clear Plastic Restorer (SB87208) before applying View Guard.
Subscribe for the latest offers and product news
Keep up to date with news and be the first to hear about new products, offers and clearance items.
