Sailrite
110 Volt Motor for Ultrafeed Sewing Machines (4‑Pin Socket)
£53.12 (ex VAT)
£63.74 (inc VAT)
Sorry, this is currently out of stock.
This option is unavailable.
2 in stock
102630 £53.12 (EX VAT) £63.74 (INC VAT)
Replacement 110 Volt, 60 Hz motor for current version Ultrafeed® Sewing Machines. This motor features a 4-pin socket that fits the plug on the 110 Volt Deluxe Foot Control with Grounded Wiring. This motor requires a custom mounting bracket from Sailrite and was not designed to be side mounted. Mounting poles are spaced 2-1/3 inches apart. This motor is for Ultrafeed machines on which the motor is mounted using the end studs.
We also sell a similar motor for legacy Ultrafeed Sewing Machines with an AC plug end (#W003Z-26). If you’re not sure which motor you need, check your existing motor to see if it utilizes a 4-pin socket or AC plug and order the same.
Please note: If your Ultrafeed has a molded plug and mounts to the machine using screws set into the motor housing, please contact us at info@sailrite.com. Neither the 4-Pin Socket Motor (#102630) nor the AC Plug End Motor (#W003Z-26) will work for your sewing machine without modifications.
Features:
  • 110V/60Hz
  • 150 watt input
  • 75 watt output
  • 1.5 amps
  • 6600/6000 RPM
  • 2 Poles
  • Grounded
  • Model TM-1150
When these say 'available to backorder' please do not order. Remaining stock is all we have left.
Subscribe for the latest offers and product news.
Keep up to date with news and be the first to hear about new products, offers and clearance items.
