Bambi
Budget Range2 AIR COMPRESSOR
£379.00 (ex VAT)
£454.80 (inc VAT)
The Budget Range2 has been developed for those users where ultra low noise and relatively small flow of air is required. With sound levels from just 40 dB(A) and almost no vibration when running, Bambi Budget Compressors can be located in the work area without causing any noise intrusion.
Where space is really limited, the “V” designated models have the same specification as the wheel mounted versions but in an ultra compact package. Standard versions have an 8 bar maximum working pressure, optional higher pressures are available on request.
Designed to require minimal maintenance and to ensure years of trouble free use, our comprehensive range meets the needs of many applications including; air-brushing, exhibition stands, glue dispensing, pneumatic controls, stapling – anywhere where compressed air is needed silently!
But, Budget Range doesn’t mean budget specification. Each model in the range has the following features as standard:
- Internally Coated Air Receiver
- Clearview Oil Level Check
- Easy to use Oil Filler Plug
- 10 Micron Outlet Filter & Adjustable Pressure Regulator
And because they’re built by Bambi, quality, ease of use and reliability come as standard on every model. A comprehensive warranty extending to 3 years on the air receiver ensures peace of mind which combined with our worldwide after sales care package guarantees you have made the right choice by choosing Bambi
Subscribe for the latest offers and product news
Keep up to date with news and be the first to hear about new products, offers and clearance items.
